You might look at inserting this as a "circuit" of the VFD block insert and
parameter list block insert (both inserted into one ".dwg" file) instead of
inserting the VFD and parameter list blocks as separate components. See if
this works: open a new, blank drawing. Use AcadE to inert the VFD at 0,0.
Then use AutoCAD's INSERT command to pop in the parameter list block. Save
the dwg file, maybe to your "USER" folder.
Now, test it. Use AcadE's INS CIRCUIT command, browse to this ".dwg" and pop
it into your electrical design. See if it works as you'd hoped. If so, you
can encode this on to your electrical INS COMP icon menu or just pop in with
the INS CIRCUIT cmd whenever you need it.
If this isn't quite what you're looking for, there are other approaches...
"rday" wrote in message
news:18326947.1075220385217.JavaMail.jive@jiveforum1.autodesk.com...
I have a block that represents a VFD. I also have a block that is a
parameter setup list for this VFD. Is there anyway to set up the VFD block
so that when it is inserted AE will also insert the parameter list block and
prompt me for it's insertion point?
