AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Insert / Edit Child Component - Error Load Failed
3 REPLIES 3
655 Views, 3 Replies
ACAD Electric 2014, when inserting or editing a child component, A lisp error occurs in the
Error Load Failed
"C:\\Users\Me\\Appdata\\Local\\Temp\\Insert_sec_trmDlgEvents,lsp"_,UNDO
I did a clean install and short of reformating my drive.  anybody got any ideas?
3 REPLIES 3
OP21
I had a similar error occur for cable tags...  Check your "Trusted Locations" under -> Tools / Options settings and verify if you have some paths missing.  Some routines and scripts are run temporarily in these locations...
This may help...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
in reply to: OP21
If I create a new user in Windows 7, The "insert_sec_trmDlgEvents.lsp" works just fine.  When another program cleans the temp file or any changes to the appdata temp directory,  the "insert_sec_trmDlgEvents.lsp" fails to load.
I found a go-around... but not the fix. The "c:\user\appdata\local\temp" is set at read only. if I remove the read only status, the lisp works. Any way to move that lisp from running in that folder?
”Boost
