As shown in the above image,I am using ace_circuit_builder spread sheet to insert CPT block ,the wire at CPT is not properly getting connected,what need to be done fixe this issue.
Below command is used to insert CPT.
(c:ace_cb_insym #xyz nil "HXF 2_ERE" #scl 8 "%N=@MOTOR_NUM@,DESC1=CONTROL POWER TRANSFORMER")
Thanks in Advance.
What i typically do in Circuit builder is extend the wire past the point where the block is inserted, this ensures that the wires are never short. they should be trimed back automatically as long as the XTERM points are in the correct spot and the correct orrienation.
