AutoCAD Electrical Forum
Include prefix in an XREF
4 REPLIES 4
pwk
400 Views, 4 Replies
I am using ACE 2009. I have been using source and destination arrows. When I look at the underlying symbol for a source arrow, I see that the XREF attribute has its prompt set to the text "to". When the symbol is inserted, the XREF tag takes on the value "to 1234" where "1234" is the destination reference number. Somehow, the text in the prompt is automatically inserted before the actual reference number.
I would like to do something similar with my own parent and child symbols. I have used the symbol builder to create a parent symbol. I have also created a corresponding child symbol. Both my parent symbol and my child symbol includes the attribute XREF. I have set the prompt for these XREF attributes equal to the text "Line". When I insert my symbols, I would like my XREF's to appear as "Line 1234". Instead, I am just getting "1234".
Can anyone tell my why the prompt text is included in the XREF when I use source/destination arrows, but it is not included with my own custom parent and child symbols?
Any help will be greatly appreciated.
Thanks in advance,
Paul
Instead of just showing the
4 REPLIES 4
in reply to: pwk
AcadE specifically looks for this on the source and destination arrows. I am
afraid this is not supported at this time for other symbols. You can set
this up in the Cross-Reference setup but then it would appear on each
reference. For example, if you set your cross-refference format to "Line %N"
and there were 2 contacts for the one parent, the XREF would be Line 1234,
Line 5678. I am guessing this is not what you wanted.
Sorry I couldn't be more help. I can log this as a wish item.
Pat Murnen
wrote in message news:6024714@discussion.autodesk.com...
and child symbols?
Thanks in advance,
Paul
pwk
in reply to: pwk
Hi Pat,
Thanks for the response. Yes, if you can log that as a wish item, that would be great. Over the years, while we were entering our references as standard text, it has been our standard practice to use the format "Line 1234". Now that I am trying to use the automatic XREF feature of ACE, it would be great if I could have them look the same.
In the meantime, I don't think it is too big of a deal. I will start using XREF's with just the line number. Hopefully it will be obvious enough that it is a reference to another line and not some other piece of information about the component.
Thanks again for your help,
Paul
in reply to: pwk
I logged it. Logging it does not mean it will be done at any given time or
with any release. It just means that it will be considered.
Pat
wrote in message news:6025029@discussion.autodesk.com...
Hi Pat,
Paul
Has this been solved with any newer versions of ACE yet? I would like the same thing happen but in ACE2012.
Sally
”Boost
