1.) Is there any way to include a User Post setting inside of the .set file?
2.) Also, is there a way to have two tagNames per row on the report instead of one?
Thanks!
Solved by rhesusminus. Go to Solution.
1. As of right now, no.
2. Not without a User Post. Do you have a more specific description of what you want?
Currently the TAGS field has one item per row, I was looking for two items per row seperated by a colom and space
Thanks!
I'm still no sure what you want to accomplish.
Lets say you have three lines in the BOM:
TAG MANUFACTURER CATALOG
K1 SIEMENS 1234
K2 SIEMENS 1234
K3 SIEMENS 5678
K4 SIEMENS 5678
K5 SIEMENS 5678
Do you want
K1 : K2 SIEMENS 1234
K3 : K4 SIEMENS 5678
K5 : SIEMENS 5678
Or...
K1 : K5 SIEMENS 5678
Or something else?
So what I am looknig for is more like:
K5 : SIEMENS 5678
Although it looks like this on the BOM:
K1, K2 SIEMENS 1234
K3, K4 SIEMENS 5678
K5
Thanks!
I'm trying to hack my own but so far I have only gotten the Report Generator to process forever, ha
Export it to Excel, and do som fancy formulas there 😄
Or... Hack your own User Post to achieve it 😄
How do I get the lisp routine to break so I can look at the data? I am setting break points in the Lisp routine from support directory and making changes and it will run when running a Report, but it won't break!
Thoughts?
I was able to create what I wanted with the following edited "pur_pbom.lsp" file.
Are we entirely sure there's no way to automate a User Post option? Anybody else want to add their 2 cents?
Wll now I am trying to have everybody have the same .lsp files for Reports . .
Mine is at: C:\Users\Public\Documents\Autodesk\Acade 2014\en-US\Support
But I haven't found an .env setting that seems to apply this to everyone if I put it on the server. . .
Am i missing somthing?
Have a look at the WD_SET_FILES setting 🙂
