I am having an issue with a single component trying to import from a schematic list. I have verified every possible issue and concern with regard to creation of both the schematic symbol, as well as the panel symbol. No errors that I am aware of. However, when I attempt to import, I am forced to choose Footprint Choice A or Choice B. Any advice or suggestions would be greatly appreciated. Thanks
Solved by ricardo_baez. Go to Solution.
Are you positive that there is an entry in the footprint_lookup.mdb that matches up with an entry in the default_cat.mdb?
Ricardo
Yes, I just verified again that both names are the same in both the footprint and default.mdb's. I have gone as far as to change out the footprint.mdb and found the same error. I believe now that there is an error in the default.mdb. However, all the checks that I run, do not show any issues or concerns.
Can you post your blocks, catalog number and manufacturer? So that I can try to replicate this problem on my end?
Ricardo
