I have been trying to find an answer to a question regarding IEEE 315 symbols with respect to the ACADE 2012 IEEE symbol library
Do anyone know if the IEEE symbol library included with ACAD Electrical 2012 is correct? The symbols look like the IEC symbols, but when I reference NFPA 79 2012 Anex E Figure D.1 the symbol selections resemble JIC symbols with a second reference to IEC 61346-2. So I'm not convinced the IEEE library with ACAD Electrical is correct. The symbol designations are also in line with IEC for the most part, but that goes against Table E.1 in NFPA 79. Can anyone shed some light on this subject or perhaps guide me to where I might find the answer?
Bruce
Electrical Designer
Preco Inc.
Hello Bruce,
Can you send your observations and references to my official email address to evaluate with figures and examples ? It will help us to understand the exact case what you mean to put up on forum.
My official address is mayuresh.athalekar@autodesk.com
Mayuresh,
All you need to do is look at NFPA 79 2012 at Figure D.1 (q) which shows examples of the symbols. IEEE 315/315A should match the ANSI Y32.2.standard. If I wanted to use the IEC 60617 then I would use that library provided by Autodesk. I had some corresponence with Doug McAlexander (Autodesk Discussion Group member) and he is in agreement with me, and in fact he stated that he submitted to Autodesk back in 2012 that the IEEE library with AutoCad Electrical 2012 was using the wrong symbols. If you have some substantiating documentation that the IEEE library supplied by Autodesk is correct I would like to see that documentation.
Bruce
Electrical Designer
Preco, Inc.
The entire body of IEEE STD 315-1975 would be VERY nice to have, as I can find no other 2D drawing or mapping (like visio or dia) that have the entire library easily available. RF cafe host something for 30 USD that has some of the symbols, but they are not as defined by IEEE 315-1975 current accepted version.
SimpleCAD advertises a full library, but I have not tested it. Cost is 139 USD.
http://www.simplecad.com/y32-symbol-library-ieee-std-315.htm
http://www.simplecad.com/electrical-blocks-iec-ans.htm
Have any other answers been posted? Does AutoCAD 2019 state full compliance with IEEE 315-1975?
There's a reason you aren't seeing much action on the Idea forums.
The developers have set it so that the first screen you see when entering an Ideas forum is the Top Ideas, not the Latest Ideas. If you go to the Latest, there are plenty of ideas popping up that don't get seen due to people not realising that difference between Top Ideas and Latest Ideas.
While the activity in the Electrical Ideas forum has dropped off a fair bit, it is still getting about one idea a week from users even if those ideas come in cluster rather than being spread out.
Regards Brad
Brad Coleman, Electrical Draftsman
