a different tag dash issue here
working on somone elses drawings
orignnaly the project settings were not set to add the IEC tag dash (corrected that)
now have a mixture of tags with a dash prefix and and without a dash prefix
now need to have all tags with the IEC dash
i would usually use the find /replace component text to change a tag number no luck there as the dash is supressed
next option would be to export tags out in spreadsheet and adjust there no luck supressed there as well
cant use the force IEC inst/loc attributes because that will reset all the hidden inst/loc codes
ony solution i can see at the moment is to go into each symbol and let it set the tag dash
open to any idea i have 400 pages to go through
If some dashes were typed in manually and some were generated by the software, there could be confusion when you try to manipulate manually. I would try exporting to a spreadsheetand remove all leading dashes from tags there. Make sure that IEC tag mode is on and set not to suppress the leading dash. Update from the spreadsheet and run retag project wide.
