AutoCAD Electrical General Discussion
stellamarisllc
Message 1 of 20 (2,126 Views)
IEC Symbols Add-in
2126 Views, 19 Replies
08-16-2012 08:01 AM
Can anyone let me know if Autodesk or another site offers a add-in package for IEC Standards? I know that it comes preloaded with the JIC. However we use IEC. Any help on this would be greatly appreciated.
testsubject
Message 2 of 20 (2,121 Views)
Re: IEC Symbols Add-in
08-16-2012 09:15 AM in reply to: stellamarisllc
From the Control Panel/Programs/Uninstall a Program, select Autocad Electrical 20XX and when you get to the Installation Dialog Box, select Add or Remove Features and select all the symbol styles that you want. It is also from here that you can add manufacturers to the database.
ACE by default installs only the JIC Library (we should be given the option to pick which library)
Bob Hanrahan
Ace User since 1998
dougmcalexander
Message 3 of 20 (2,111 Views)
08-16-2012 09:00 PM in reply to: testsubject
Actually you do get the option.  If you select IEC as your default design style you will get the IEC libraries instead of the JIC.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
stellamarisllc
Message 4 of 20 (2,107 Views)
08-16-2012 09:56 PM in reply to: testsubject
Thanks so much for your help. Chaz Viator Designer Stella Maris LLC 930 West Pont des Mouton Lafayette, LA 70507 Phone: 337-504-5128 Extension: 1024 Fax: 337-504-5344 www.stellamarisllc.com[Description: Description: Description: logo][Description: cid:image003.png@01CD756E.CA2D4830]
Member
sfcbatch94
Message 5 of 20 (2,078 Views)
08-18-2012 10:39 AM in reply to: stellamarisllc
Hi Doug,
I've also encounter same problem with IEC symbols, as you were saying it has an option wherein the default drawing can be set to IEC, can you please tell how can this be done. Please forgive me, I'm still new in autocad electrical. Thanks in advance.
Do on what you love to do... success comes next.
stellamarisllc
Message 6 of 20 (2,036 Views)
08-20-2012 09:08 AM in reply to: stellamarisllc
I have been able to load the IEC Library but some of the slides are loading the IEC Symbols and some or still loading the JIC symbol!
Example: The title says IEC: Push Bottons, and the preview is showing the correct IEC symbol for push button, However when you click on the push button icon it shows up as a JIC symbol in model space. It is not doing this for all the slides, just certain ones.
Can anyone shead light on this subject?
testsubject
Message 7 of 20 (2,034 Views)
08-20-2012 09:43 AM in reply to: stellamarisllc
The first place I would check is in the Project settings and verify which libraries are selected in the "Libraries and Icon Menu Paths" section. This area determines which symbols are inserted from the menus. These setting are Project specific.
Bob Hanrahan
Ace User since 1998
dougmcalexander
Message 8 of 20 (2,026 Views)
08-20-2012 12:56 PM in reply to: stellamarisllc
If you have already inserted symbols into your drawing from the JIC library they remain in your drawing, even if deleted. You should purge your drawing of unused blocks. Type PURGE at the command line and press your Enter key. Purge unused blocks.
Doug McAlexander
testsubject
Message 9 of 20 (2,023 Views)
08-20-2012 02:39 PM in reply to: dougmcalexander
Good Idea Doug. I forgot about that.
Bob Hanrahan
Ace User since 1998
stellamarisllc
Message 10 of 20 (1,966 Views)
08-22-2012 12:07 PM in reply to: stellamarisllc
In my Schematic Libraries I removed the “JIC” ones and added the “IEC-60617” and moved it to the top. My Schematic Icon Menu File reads
“ACE_IEC-60617_MENU.DAT”
My Panel Menu is still set to the default. Would that need to change as well?
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
