ACADE does not scale symbols you make according to which library you have selected. The included libraries are simply symbols that were drawn at different sizes to accommodate different border sizes. The symbols are named the same in each library so you can do a library swap. When you do a library swap, ACADE simply pulls the same symbol name from a different library, so the geometry appears different. I have a custom library of my own. I place it first in the library path. I use the standard icon menu to pick the components. If ACADE finds a VLT1A in my library first, it uses mine, otherwise it goes to the next library in the path and looks for it. Be careful when swapping from JIC to IEC or vice versa. The IEC symbols are drawn in metric units. You will need to scale as appropriate.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
