Show only
Search instead for
Is there a way to import the spreadsheet file generated via DataExtraction command back into AutoCad? I want to modify it in Excel and apply the changes to the drawing.
AutoCAD Electrical has its own Export to Spreadsheet and then Import from
Spreadsheet that does this. Does it not have what you are looking for?
Pat Murnen
wrote in message news:5952267@discussion.autodesk.com...
AutoCad Electrical Import/Export is not good enough. It just includes electrical components while DataExtraction has a lot more. I need a way to import it back after changing it.
How can i import the excel file that i got from dataextraction. After my data is updated i want to import it into autocad through dataextraction excel.
