AutoCAD Electrical Forum
How to print the project to a PDF document
2 REPLIES 2
491 Views, 2 Replies
    I using the ACE 2013,when I want to print a project to a single PDF document,I do not know how to setting!Man Sad
2 REPLIES 2
JohnSmith5014
Hi
In the page set up manager - I have model space set to print AcadE to PDF for each drawing - usually on ISO Full bleed A3.
I then use publish project to DWF and when the dialogue box opens change it to pdf.
In the options I then set multi page so that it creates one pdf with all drawings.
It works for me - but there could be an easier way.
Regards
John
CAD-ICE
Hi there!
have a look at this weblink which shows how to publish one ore more project drawings in a single pdf file.
Hope this helps you on the right track!
Regards, Gary
http://autodesk.typepad.com/systemsdesign/2012/03/how-to-create-one-pdf-file-that-contains-the-whole...
”Boost
