AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
How to get drawing without cross refernce for component tags
1 REPLY 1
343 Views, 1 Reply
when i  create a new project using circuit builder to insert drawing.I see crosreferenceses for the component tags in this drawing. (Please look at the provided figures for refence).
I need the drawings without crossrefenceses for component tags. Please help me slove this.
1 REPLY 1
Hi Laki.anu87,
What you are seeing at the end of the component is not a component cross-reference.
Your Component TAG is using %F and %N.
% F is the Family code
% N is the Format Reference. depending on what reference option you choose you will see different results.
The Default option is  Reference Numbers (rung numbers)
Then you have X zone  and X-Y Zone .... your drawing appears to be using X-Y Zone.
And its set up for Vertical rungs not Horizonital...
If you don't want to use X-Y Zone... then change it, or use Sequential, insead of line reference.
Here are some example of what the options would look like.
Examples:
The first  4 use  Line Ref (The suffix) so repeats on the same line get  " ", A, B, C, etc, or " ",1, 2, 3, 4, etc.
Rung Ref Numbers          (PB123, LT124, CR123, etc)
X Zone (Alpha)                 (PBA, PBD, PBX, LTA,LTE, LTY, etc)
X Zone (Num)                   (PB1, PB15, PB26, LT1, LT12, LT23, etc)
X-Y Zone (alpha-Num)     (PBA-1, PBD-7, PBF-2, LTA-1, LTE-9, LTZ-99, etc)
Sequential                         (PB1, PB2, PB3, LT1, LT2, LT3, CR1, CR2, CR3, etc)
I hope this helps,
James Alger
SolidCAD
”Boost
