If you're referring to the QBOM check button along the left hand side of the
Insert/Edit dialog, then any USER1 through USER3 field values you enter into
the catalog lookup file should show up as additional lines added in at the
bottom of the overall DESC column in the Quick BOM check dialog.
"douyi" wrote in message
news:10993761.1093958905406.JavaMail.jive@jiveforum1.autodesk.com...
> Hi, I'm using WD 17 and want to customize the Quick BOM check results by
adding my own database "user1" field. I can do it at BOM report, but I still
wanna add this field to Quick BOM check when I add or edit a component. What
should I do? Please help me. Thanks in advance.
