AutoCAD Electrical Forum
How to Linking between Parent & child elements are in Different drawing Sheets
1 REPLY 1
laki.anu87
1147 Views, 1 Reply
Explain the procedure to link the components between the sheets using circuit builder concept . Example : link between the parent in sheet#1 to child componenet in Sheet#2.
1 REPLY 1
s.wile
in reply to: laki.anu87
Are you using a project file? Are both drawings inside the "active" project? If so after placing the child component press the Project button in the "Edit Child" dialog box. This will list all parents of the same family type project wide.
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
”Boost
