It seems that no matter how I insert the shield, the part that has the extra wire connection point for the drain wire is always to the right. The problem also is that if I try any method to flip the shield over so that the drain wire connection can be connected on the left, the wire still wants to approach from the right. Only after inserting the shield, connecting the drain, then flipping it all together, will the orientation produce the desired results. I would like to have the option to flip that drain connection as I am inserting the shield.
Ronald Michaud
Electrical Engineer
Darly Custom Technology Inc.
www.darlytech.com
Via Lite V3 thru ACADE 2011
