I am currently setting up a block library for our company. We have added several multipin blocks with unique catalogs and family codes. We followed help file and made the TAG the same as the FAMILY attribute. Many of these blocks have NO,NC or NONC contacts. I would rather have one symbol .dwg rather than diffrent symbols .dwgs for each family code. Is there a way to bypass family mis-match alert window? Is there an AutoLISP command I can use within in the WD_SYM_LIB_RESIZE macro to make all of the FAMILY tags match?
Thank you!
Solved by dougmcalexander. Go to Solution.
My experience has been that no, you cannot bypass the warning. The family attribute is also used to tell ACADE what table to use for the catalog lookup to find the part number. Even though you may use an identical symbol for a NO pushbutton contact as you do for a relay, it is not the same part number and the Family attribute points you to the corresponding table, ie CR for the relay.
Scott
"Is there an AutoLISP command I can use within in the WD_SYM_LIB_RESIZE macro to make all of the FAMILY tags match?"
Are you looking to change the font height on the TAG attributes on your entire symbol library? If so, use the Modify Symbol Library command.
I hate to differ but the family attribute is actually used to prevent a mismatch of parent and child devices. For example, if you try to associate a N.O. control relay contact (Family code CR) with a motor starter coil (Family code MS) AutoCAD Electrical will pop up a warning. Consider it AutoCAD Electrical's version of the Department of Family and Children Services (DFACS).
The 2nd and 3rd character of the block name (filename) actually determines the search table for Catalog Lookup. The misconception about the Family attribute is very common. I thought the same thing when I started using the software back in 1997.
If your symbol is a parent that would never adopt children, you could forgo the Family attribute. However, Symbol Builder will report an error because it expects to see the attribute.
Hint: You can add the WDBLKNAM attribute to a block and enter an alternate table name as its default value for the Lookup to the direct to a different table. This is helpful for footprints, since footprints do not follow the same block naming convention as schematic symbols. Also notice the schematic terminals include this attribute, since their filenames do not follow the same rule as other blocks, and they need to find the TRMS table for part number assignment.
Controlling What Table Is Selected For Catalog Lookup
Doug is correct. I dug into this post back when someone had a symbol that wasn't pulling the proper catalog info. I too went straight to the FAMILY attribute and was puzzled why the catalog wasn't working as expected.
I was wondering, is there was a way to set the default value for the FAMILY attibutes of all blocks in the library to match?
Glad you cleared that up Doug.
Scott
