Hi
I would like to insert vertical terminals on vertical wires that show the wire number and tag aligned with the wire. I would Also like to insert horizontal terminals on horizontal wires that show the wire number and tag aligned with the wire. I have blocks HT0W02.dwg (horizontal) and VT0W02.dwg (vertical) which i have altered to align the wire numbers etc. The problem is that when i insert one of each it shows up both (in the terminal window) in the 'block' coloumn as HT0W02 but if i click on 'show/edit miscellaneous' it shows both as Block Name VT0W02. Whats am i getting wrong? Are the blocks i'm adjusting the correct ones?
regards
Shaun
