AutoCAD Electrical Forum
Hiding DinRail
3 REPLIES 3
1238 Views, 3 Replies
Hiding DinRail
How do you hide DinRail behind manual inserted footprints? If I create an
footprint - Manual - I can't get the Dinrail to "hide" behind it. I try Draw
Order, Send to Back and Send Under Objects, but I can't get it to hide.
P
3 REPLIES 3
btackes
You need to add a wipe out to the footprint symbol
Go to Draw - Wipeout. Click around the edges of your object (note that you
can't get curves using this command).
After you have finished select the wipeout object and send it to the back,
then send your Din-Rail to the back.
To avoid doing this for each individual block, open the block dwg and do the
wipeout there, send it to the back and save the
block and then do a block update..
Regards Brad
"Paul M" wrote in message
news:5889908@discussion.autodesk.com...
P
Thanks for the help
"Brad Coleman" wrote in message
news:5890579@discussion.autodesk.com...
Regards Brad
P
”Boost
