Is there a setting to hide rating and description attributes on panel footprints? I know how to hide them after they have been inserted but I would prefer that they not show up when inserted.
Modify inserted block WD_PTAG
Located in panel subdirectory of Libs.
Do a block edit and change the visible flag to yes (you will need to enable properties box ).
Changing status here will be permanent change for any future insertions
Turn the PRTG & PDESC layers off. This will hide the layers on the dwg but leave them available to see with a few clicks.
Regards Brad
Brad Coleman, Electrical Draftsman
Attribute Template Drawings
You can set up to have visible attributes added to any footprint automatically at footprint insertion time. Using non-intelligent footprint representations can insert with smart AutoCAD Electrical attributes added automatically, on the fly.
There are five attribute template drawings:
•wd_ptag_addattr_comp.dwg. component footprints
•wd_ptag_addattr_trm.dwg. terminal footprints
•wd_ptag_addattr_wtrm.dwg. terminal with wire no. as terminal number
•wd_ptag_addattr_itemballoon.dwg. balloons
•wd_ptag_addattr_pnltermstrip.dwg. terminal footprints (when inserted by Level/Sequencing tools)
What I've done to solve this is to hide the RATING and DESC attributes in the original block dwg file.
AutoCAD Electrical Steps:
1. Open the symbol DWG file.
2. In the "Schematic" Ribbon, Under "Edit Components", expand the drop-down arrow next to the Attribute Edit commands
3. Select "Hide Attribute (Single Pick)
4. Click the attributes in the symbol file that you want to make invisible (you'll see a visibility change confirmation above the command line)
5. Save and Close.
Alternate Process:
2. Select the attributes in the symbol file that you want to make invisible.
3. Open "Properties" tab (type Properties)
4. Under "Misc", select the "yes/no" drop-down next to "Invisible" and select "Yes"
5. Save and Close.
Hope this helps. Please mark as "Solution" if this solves your particular issue. Good Luck!
