AutoCAD Electrical General
Active Member
Message 1 of 6 (375 Views)
Hanging lock files
375 Views, 5 Replies
02-24-2012 11:20 AM
I have a project folder that holds my wdp file and drawings.  When in the project, autocad will open a lock file for the current drawing open.  But whenever I plot the project, autocad will open lock files on all of the drawings in the project and plot them.  When finished the lock files are still in the project folder and I get an error message when I try Autocad Electrical to page between drawings.  And I can't delete the lock files until I shut down Autocad. Both the dwl and dwl2 files are created when plotting.  This happens whenever I am working from the server or on my desktop.  Has anyone seen this behavior and does anyone have a fix?
Valued Contributor
sonny3g
Message 2 of 6 (370 Views)
Re: Hanging lock files
02-24-2012 01:07 PM in reply to: johmag357
Make sure the drawings close after plotting.  Sometimes they remain open in the background until you manually close them.  Good luck.
Scott
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
Active Member
Message 3 of 6 (368 Views)
02-24-2012 01:12 PM in reply to: sonny3g
I am in SDI mode and there is only one drawing open.  This just started happening recently.  Don't know what to make of it. Can't think of any change that might be causing it?
Distinguished Contributor
Message 4 of 6 (344 Views)
02-27-2012 07:20 AM in reply to: johmag357
Are your project and drawing files on a network? I used to have this problem a lot.
I now work with a copy of the project on my local drive and not only does this no longer happen but ACE works much faster.
Edit: I also always work in SDI mode.
John
Active Member
Message 5 of 6 (337 Views)
02-27-2012 08:28 AM in reply to: johmag357
No, I actually moved a project to a folder on my computer and opened and printed it out an the same thing happened.  Whatever this is, it happens from within autocad as far as I can tell.
rhesusminus
Message 6 of 6 (324 Views)
02-28-2012 04:22 AM in reply to: johmag357
Just for the fun on it...
If you used the WHOHAS command in AutoCAD, for one of the "locked" files, when they are NOT open in AutoCAD... .What does it say?'
THL
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
