fdna59
Along the bottom of your screen where you have the "buttons" for OSNAP,
SNAP, GRID, etc...you should see one that says DYN, you can turn the new
Heads-Up display off here. You can also right-click and go into more
settings regarding this feature.
I hope this helps!
Jared (Autodesk, Inc)
wrote in message news:4877467@discussion.autodesk.com...
Steve,
Thanks for the info.
Maybe is wasn't clear on the picture or called it by the wrong name.
What I want to get rid of is the little shaded rectangle that appears below
the cross hairs telling you what to do such as "pick other corner"
While it may be helpful if you are a new user, I find it very annoying.
Chad
