AutoCAD Electrical Forum
Global attribute switch
1 REPLY 1
173 Views, 1 Reply
Is there a way to turn on/off attributes globally?
I am adding locations to components on an existing schematic to easy creating panel layouts, and the "loc" attribute seems to be turned on for all components on the drawing.
I don't need the location to show on the electrical schematic.
1 REPLY 1
You should be able to just do this by turning off the LOC layer. The LOC code attribute should be getting automatically placed on this layer, therefore turning it off should "hide" all of the LOC attributes in that drawing. Hope this helps!! -- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc "fdna49" wrote in message news:21563245.1081882065033.JavaMail.jive@jiveforum2.autodesk.com... > Is there a way to turn on/off attributes globally? > I am adding locations to components on an existing schematic to easy creating panel layouts, and the "loc" attribute seems to be turned on for all components on the drawing. > I don't need the location to show on the electrical schematic.
”Boost
