AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
From/To Report
7 REPLIES 7
Message 1 of 8
396 Views, 7 Replies
From/To Report
I am creating a From/To report on wires numbers but would like to understand how AutoCAD Electrical determines CMP1, PIN1, CMP2 & PIN2.
Can someone please advise.
Thanks in advance.
7 REPLIES 7
Message 2 of 8
pqphillips
As I understand (and I might be wrong), the FROM/TO information is "read" from the start of a wire to the end, and the wire connection points at each end are what determine what CMP1, CMP2, PIN1, and PIN2 are.
In laymans terms, it would follow this pattern:
1) To/From finds a wire.
2) To/From looks at the start point of the wire and pulls CMP1 (the tag number of the device it's connected to) and PIN1 (the TERMXX value for the connection point) and places it into the report.
3) To/From looks at the end point of the wire and pulls CMP2 (the tag number of the device it's connected to) and PIN2 (the TERMXX value for the connection point) and places it into the report.
4) To/From repeats the process until all wires have been accounted for.
Message 3 of 8
dougmcalexander
The wire list is compiled using the sort order of the drawing.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 4 of 8
drathak
in reply to: dougmcalexander
To be clear, you mean this setting, right?
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
Message 5 of 8
in reply to: drathak
Thanks.
The sort order setting is set at no override. What does this mean? What is the default setting?
Message 6 of 8
dougmcalexander
Click the arrow and you can read the various sort orders that are available. For example, the default for horizontal ladders (IEC style) is top to bottom moving right across the page.
Doug McAlexander
Message 7 of 8
How does it generate the report if you leave the sort order set at no override?
Message 8 of 8
The drawings are PLC Wiring Diagrams and I want my report sorted so that all the PLC addresses appear as CMP1 and the components tags appear as CMP2 in which I had previously but now the PLC addresses are appearing in both fields. I am not sure what I have done to make this happen. Can you advise.
”Boost
