Dear Sir/Madam,
I'm using Electrical Autocad 2011. i need to take From/To Wire report. As per the diagram i attached. I need Report format as
R to Q1.1 & R To Q2.1 & R To Q4.1 Like this. (R & Q1.1 - all are not wire No's its Symbol's wire connection terminal No's)
But in report i got,
R to Q1.1 & Q1.1 To Q2.1 & Q2.1 To Q4.1
How can i get report as R to Q1.1 & R To Q2.1 & R To Q4.1 Like this. Is there any posibilities.
Please Guide me & Help me
Thanks & Regards,
Saravanan
Solved by rhesusminus. Go to Solution.
AS AutoCAD Electrical works with wire networks, you will have to draw it differently to get it as you want:
Not the most "beautiful" way to do it, but it works. You could always "cheat" by putting these wires on a layer that doesn't plot, and then draw a polyline that shows in the plot...
Thank you. Thank you very much for your Guidance
Thanks & Regards,
Saravana
