I have a relay contacts 11-COM, 12-NO, 14-NC. I assigned them as Form-C relay as (3,11,12,14). When I ran the Electrical Audit, it gave me "pin duplicate component assignments" for pin 11. Is there a way to avoid this error?
Versions 2013 and 2014 include an NFPA library, which has an actual Form-C relay contact symbol. It can even be swapped out for its IEC equivalent using the Library Swap utility. There will be no duplication of pin 11 in this case.
It is included with the NFPA library. It was always in the IEC libraries.
