I'm having problem when trying to insert Schematic Components (list) to Panel layout. It was running and never pull out the list to insert. I ended crash closing Electrical Autocad by Task Manager. I'm using Electrical Autocad 2014, the database is located on the network drive so that everybody can access to it.
* Second problem so far by now is that i'm not able to link PDF documents with the catalog. I put PDF on the network drive and copy the links to the catalog (access) but when i hit Catalog Check then Weblink. Nothing happen. I tried to move the pdf to the local drive and still not working either.
Please help. The schematic link is critical for me because it's 50% strength of Electrical Autocad.
Thank you
Trung
Solved by rhesusminus. Go to Solution.
HI Trung,
I have a few things for you to check.
You can only link to websites with the Weblink tool. if your hosting the PDF on a website then yes you can link to it.
Otherwise the weblink tool can't find the item to open in a web broswer.
Normally you path to the Manufacturers Website.
I hope this helps,
James
Hi James,
Thank you for your reply. I got the latest update in my software already. This morning i checked and it took me almost 20 min to change a footprint from one to another. I got the latest version of Sevice Pack for Electrical Autocad already. In the past (version 2004 and 2009) i could store my PDF in my locad hard drive and Electrical Autocad will open PDF reader to read. Coming back to the speed of the database, we located our database in a network sharing server and map as a drive. Is there anysetting that i need to tell my IT department to set it correct.
Thank you
Trung
Hi Trung,
Well for best practices, Do not share any of the .dat files (menu files)
They slow down the network since the are constantly running.
Leave all support files on the c:drive.
The Projects, and Databases (catalog database, footprint database, etc ) can be shared.
(do not share the project database; the database stored in the "users" support Section)
as for the database speed...
A 20 min lookup? wow, how fast is the network?
hmm I guess you could try repairing the database in Access. (compact & repair )
let me know if the repair helps.
James
The weblink function works perfectly with locally stored PDF's, using an UNC or mapped path.
To check whats happening, we can turn on some debugging tools in AcadE, that will put extra information to the command line.
Type the following commands to the AcadE command line:
AEONTIMER
AEONMDBDEBUG
AEONLISPDEBUG
Now, run the slow command again, and press F2 to open the command line when it's done.
Have a look for something suspicious, and maybe post the result here as well?
Thank you for your tips about debugging. I moved the support drive to local drive and try to Insert Components from Schematic. It war running for more than an hour already and still waiting. In the end i got Fatal Error Message. Any ideas what caused it?
Regards
Trung
Type LOGFILENAME in AcadE to see what file the command line is logged to.
Then type LOGFILEON to start logging to that file.
Also, remember to turn on the above mentioned debug functions.
Now, if/when it hangs, take a look at the log-file for debug information.
Same fatal error happen. Please see the log file for the process. I tried to pull an 24vdc distribution schematic (see attachment) with 5, 6 components and terminals nothing much at all
Regards
Trung
Does it stop on the same component every time?
I.e: IN:wd_cat3_getcat2 for=AB cat=800T-FRXT6AP asmb= table=HPB12M
Seems like it stops while trying to detemine what table in the catalog to use for this component.
It's freezing when i tried to insert a PB and lookup for a part. This coming back to the original question that Electrical Autocad freeze when lookup for part. My computer is good enough to handle the load from AE (Intel Xeon E5 2670, 64GB Ram, Windows 7 Pro). Let me try on another machine. The last time i tried , it freezed. Is there any setting for the network drive that i don't know of? The next thing i will try is move the database to local drive and see the performance of it.
Trung
Seems like theres something wrong with your default_cat.mdb maybe? Have you tried to open it in Microsoft Access, and run a "compact & repair"?
Hi Trung,
Close AutoCAD Electrical and MS Access. (don't have the databse open in any programs)
Look for an "LDB" (.ldb) file.
If it exists when the database is closed, Delete it, then you should be able to edit the database again, as long as there are no Folder Restrictions.
James
