AutoCAD Electrical Forum
Footprint DB
1 REPLY 1
3650 Views, 1 Reply
Footprint DB
I have created a custom catalogue DB secondary file. I am now trying to create a custom footprint DB. However the command AEFOOTPRINTDB just writes to the default footprint.mdb file. How do I write to my custom footprint.mdb
Thanks in advance.
1 REPLY 1
dougmcalexander
You can create alternate tables in the same footprint database. Just name them manufacturer name_WD. When inserting a footprint from the schematic click the bottom center to switch to wiring diagram tables. This is intended for switching between plain or wiring diagram style footprints but it us really allowing you to alternate between two different footprints.
You can also place an alternate footprint_lookup.mdb file, named the same as the main, into a project's folder and the software will use that one instead of the main one.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
