AutoCAD Electrical General
Active Member
Message 1 of 2 (107 Views)
Flatshot Base Point
107 Views, 1 Replies
10-18-2013 09:36 AM
I am using ACE 2013. I recently used flatshot and when creating a new block from the original the command created a worthless base point on it's own. I dont know how it choses this spot but I ended up making it chose the spot I wanted by centering and then offsetting the zoom screen. It seemed to pick a point near the center of the zoomed window. Is there a better way to pick a base point? I tried right clicking and picking base point and then selecting a point on the component before dropping the block onto the page and that didn't work. Any knowledge of how this works or how I am intended to select a base point when using flatshot would be greatly appreciated.
*Expert Elite*
Message 2 of 2 (72 Views)
Re: Flatshot Base Point
10-24-2013 07:42 AM in reply to: bcc2
You should be able to open the block drawing and type Base at the command line to change its base point, after it has been flattened.  This is true of any AutoCAD drawing.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
