AutoCAD Electrical Forum
Fixing fonts
1 REPLY 1
432 Views, 1 Reply
Fixing fonts
We are completing a series of drawings that have been worked on within various offices, using AutoCAD 2011.  As a result, we have differing fonts.  Is there an easy way to make a global change to fonts within the project?
Kind Regards,
Mike
1 REPLY 1
rhesusminus
Hi Mike.
Depending on what kind of text that's used (mtext or single line texts (or attributes)), you can solve this using a script.
Create a SCR-file (using notepad) and type something like
-STYLE
WD_IEC
ARIAL.TTF
0
1
0
No
No
Here, WD_IEC is the text style we want to change the font for. This will update all single line texts/attributes using this text style.
Now, you can use the project wide utilities to run your script for all drawings in a project.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
