The Special Explode command strips out all attributes and returns the
symbols to dumb geometry and text. I'm baffled by your customer's request.
Even dumb AutoCAD can work with attributed blocks. AcadE simply has a
specific naming convention for the attributes.
wrote in message news:5981465@discussion.autodesk.com...
Is there a way to completely convert an ACADE file (using 2008), including
ACADE blocks etc, to a standard line for standard (non attribute use) in
ACAD. Our client will point blank not accept the .dwg file in ACADE Format
because of its intelligent attributes etc. ....drawings fine, files no!
I know I can explode and delete all the attribute names but for 150 drawins
this is a bit tedious. Please advise.
Thanks in advance!
KC.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
