AutoCAD Electrical Forum
Fan in to cables
3 REPLIES 3
256 Views, 3 Replies
Fan in to cables
I have tried to follow the help "To show source and destination markers on wires". Also looked at earlier postings.
What I want to do is:-
Fan in 2 or 3 wires into a cable that goes to a pre-wired device (e.g. a optical sensor) that may or may not be on the same drawing page.
I assume that the individual cores will have wire numbers and the multicore cable will have a cable number.
Can a cable (on layer _MULTI_WIRE for example) have source and destination arrows?
How do I actually draw the fan-in? Is there an example tutorial for us thickies?
Where I have a multicore cable which is pre-wired with connectors on both ends (such as a Brad Harrison extension cable) should this be drawn as a wire or as a cable?
Using 2005 BTW.
John
3 REPLIES 3
Heather S \(Autodesk\)
Horizon,
In the AutoCAD Electrical 2006 Help, review the Advanced Productivity topic called 'Showing source and destination markers on cable wires.' This deals with Fan In/Out.
*Edited to say that I just noticed that you have 2005 installed. I'll create a PDF of the file and attach later this morning.*
Hope this helps!
Heather Schwartz
Autodesk/ AutoCAD Electrical DSS
Attached is the PDF mentioned in my previous post.
Heather Schwartz
Autodesk/AutoCAD Electrical DSS
Thank you for that - I will study carefully!
John
”Boost
