Are you saying that you are able to launch it 4-5 time and then this error
happens and then, maybe if you re-boot, you are able to launch it 4-5 times
again before this error happens or were you just able to launch it 4-5 time
total and now it will no longer work no matter if you re-boot or not.
Steve
wrote in message news:5211307@discussion.autodesk.com...
After launching ACAD2007 Electric 4-5 times the program throws the error
message "Fail to create CommCntrClientSink object" if you select the ok
button the programs goes ahead and launches but with the error message
acade.arx cannot find a dll file or other file it needs. the program will
also fail to launch correctly if the conventional acad 2007 is launched
