AutoCAD Electrical Forum
FATAL ERROR: Unhandled Access Violation 0x006c Exception at df085eabh
5 REPLIES 5
eunice.chagoya
1197 Views, 5 Replies
Good day:
One the users I support is experiencing a problem with AutoCAD 2013 Electrical, when trying to launch or start the program:
FATAL ERROR: Unhandled Access Violation 0x006c Exception at df085eabh.jpg
He is using a Win7 x64 bit machine.
He is not able to work.
In addition, is there any documentation were I can learn to read those kind of messages, to be able to troubleshoot.
Thank you.
Tags (1)
5 REPLIES 5
If you right click on the autocad Icon and do run as Adminstrator, does this error occure
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
To resolve this problem, go to the following website and download the Certified drivers for your Graphics Card:
Find Recommended Hardware
Make sure you uninstall the current driver using the "Device Manager".
Hope it helps.
Jon Dean
eunice.chagoya
in reply to: Jon.Dean
Thank your for your replies.
Can you please tell me, under which Product or Suite can I find AutoCAD Electrical 2013, I only see AutoCAD product and Autodesk Product Design Suite, but under this options I cannot see the AutoCAD Electrical.
Thank you.
Eunice Chagoya
Jon.Dean
in reply to: eunice.chagoya
Just select AutoCAD, the graphic requirements are the same.
Jon.
Jon Dean
eunice.chagoya
Thanks for the advice.
Is there any way or guide to interpret/troubleshoot when an "Unhandled Access Violation" or and "Exception" error appears?
”Boost
