AutoCAD Electrical Forum
Export to Spreadsheet Feature
3 REPLIES 3
NewAlf
204 Views, 3 Replies
Can someone please show or point out how to use the "Export to Spreadsheet" feature for your CUSTOM MADE blocks?
So, if the custom made block has a description line in it, I want to be able to export that to spreadsheet.
3 REPLIES 3
JeffatSJE
in reply to: NewAlf
if the block conforms to ace standard component blocks then you can use the components report to excel file format.
NewAlf
in reply to: NewAlf
How do I make sure my block meets that standard?
JeffatSJE
in reply to: NewAlf
that's easy just insert an ACE intelligent block, explode it and use its attributes in your new block also make not of the name of the block the first three or four letters are important refer to online help for block naming conventions.
”Boost
