I was wondering if there was a solution to this error?
Since yesterday I get the exact same error, and I can't figure out what has changed.
My wd.env hassent been changed as far as I know.
And all my 'default' .wdp files are responding in the same manner.
If there is a solution/ answer to this problem could some one please inform me...
You can check a few things to see what may be causing this.
Check the project properties to ensure the path to the database is correct.
Also, try deleting the LASTPROJ.FIL file in the following location...
C:\Users\*Owner*\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User
--Hope this helps
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
