AutoCAD Electrical General Discussion
Active Member
MaxTec
Message 1 of 10 (5,685 Views)
Error 2343 eval.msi don`t install
5685 Views, 9 Replies
05-31-2011 09:34 AM
Hi
I cant install eval.msi placed in VBA Enabler folder Autocad 2011. It shows error 2343
How can I install that?
My system Windows XP SP3
Thanks!
Employee
MinKeng
Message 2 of 10 (5,677 Views)
Re: Error 2343 eval.msi don`t install
05-31-2011 07:37 PM in reply to: MaxTec
Hi MaxTech,
Are you trying to install VBA enabler for AutoCAD 2011?
You can download it from this location:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14889082&linkID=9240617
Starting with AutoCAD 2010, VBA is no longer part of the default AutoCAD installation and must be downloaded and installed separately.
By the way, eval.msi normally resides in [SetupRes] folder and it is not meant to be installed.
Anyway, you should always install the product using the Setup.exe in the root of the install media.
Thanks.
Min Keng
Active Member
MaxTec
Message 3 of 10 (5,667 Views)
06-01-2011 04:14 AM in reply to: MinKeng
Hi
I tried, don't work.
I tested in 3 computers, but don't install. I tried install also in Windows 7 don't work .
Thanks.
Employee
MinKeng
Message 4 of 10 (5,657 Views)
06-01-2011 08:27 AM in reply to: MaxTec
Is there any error message? Perhaps a screen shot will be useful.
Thanks.
Active Member
MaxTec
Message 5 of 10 (5,654 Views)
06-01-2011 09:12 AM in reply to: MinKeng
Screenshot
Thanks.
Employee
MinKeng
Message 6 of 10 (5,642 Views)
06-01-2011 06:12 PM in reply to: MaxTec
Hi MaxTech,
Please don't double click on eval.msi to install as mentioned earlier.
If you are looking for VBA enabler, please download it from:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
In this page, please download AutoCAD 2011 VBA module 32-bit (exe - 72064Kb) and execute it from there.
Autodesk has begun the transition of VB customization from VBA to .NET technology. This transition will occur over a few years. During this time, Autodesk will provide documentation and other assistance to help our customers and developers migrate from VBA to this new automation technology. Starting with AutoCAD 2010, VBA is no longer part of the default AutoCAD installation and must be downloaded and installed separately. If you utilize VBA macros in your work environment, they will no longer work unless the VBA module is installed on your system.
Refer to this link for more information:
Min Keng
Active Member
MaxTec
Message 7 of 10 (5,632 Views)
06-02-2011 04:32 AM in reply to: MinKeng
Hi
Thanks for your help.
I had done this before, but does not work.
Employee
MinKeng
Message 8 of 10 (5,628 Views)
06-02-2011 08:28 AM in reply to: MaxTec
May I know what exactly you are looking for?
Min Keng
Active Member
MaxTec
Message 9 of 10 (5,593 Views)
06-03-2011 10:26 AM in reply to: MinKeng
I need Autocad Electrical 2011 API object model documents
Member
alexislarrahona
Message 10 of 10 (3,809 Views)
09-11-2012 08:11 PM in reply to: MaxTec
Hello!
I also I have the same problem but with Autodesk 3ds Max 2011.
When installation is finalizing two windows appear: the first is called "Setup Initialization" and the second contains the following error:
"The system can not find the file specified"
C :/ Autodesk/Autodesk_3ds_Max_2011_English_Win_32-64bit/SetupRes/eval.msi
I would be very grateful if someone could help me on this site.
Greetings!
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
