I am having an issue with acade 2014. My electrical commands will not work (wire, right clicking component) but acad seems to work ok with lines and aving. I have seen this problem other places with no clear answer. I have seen hints that it is an issue with the file pathes.
Here is a previous post with a similar problem I noticed. http://forums.autodesk.com/t5/AutoCAD-Electrical/Electrical-commands-not-working-in-AcadE-2012/td-p/...
Please help...I am really hearing it at work for my projects being slowed to a halt.
So, I guess you've tried the tips in that thread 🙂
Try resetting the settings, like in this post:
http://forums.autodesk.com/t5/AutoCAD-Electrical/resetting-ribbon/m-p/4769801#M33888
Thank you so much. I was not aware of this feature. I am still curious as to what caused this, and if anybody has a solution where I would not have to reset all of the default values I would appreciate. But this will work just fine in the mean time. Thank you again.
