Hi, I'm wondering if anyone knows of a way of getting the symbol builder options back after you have already built a device using the symbol builder. The closest thing I've come across is "bedit" which pulls up some of the options available when you build a symbol, but not all. Really what I need is the ability to add, delete, and move the wire connection points on the symbol. As far as I know, those were only available from within the properties box while using the symbol builder. Please help if you know the answer to this.
Thank you!
Just select the symbol name you want to edit in the Symbol Builder Create/EDIT dialog, and press OK 🙂
THL
Dam. That was looking right at me wasn't it?
I actually tried that a few days ago, but instead of using the pull down, I selected the symbol using the "select objects" option. But I don't think that worked the same. I think AcadE thinks you're creating a new block/symbol off of the symbol you selected at that point.
Choosing the symbol fromt he pull down was definitley the way to go.
Thanks for your help!
