Hi Pat,
The check box you indicated was checked. I still get the feeling something else is affecting the Item number assignments. Apart from being grayed out, if I select Project Find/List, AE hangs indefinitely and task mgr is the only way out. Also, if the item is already assigned in the database it doesn't seem to acknowledge the item even if I re-select it from the default catalog. I might get the assigned item number or nothing (NEXT is also grayed out.
I'm getting more "gray" on figuring this one out...
Omar
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
