AutoCAD Electrical General
New Member
e-peery
Message 1 of 2 (343 Views)
ESC key stops working
343 Views, 1 Replies
07-01-2013 07:41 AM
I've found that if I have CX-Programmer (PLC programming software from Omron) running, the ESC key completely stops working.  I've only found one other reference to this conflict which can be seen at this link, but it is in AutoCAD LT.
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCad-2012LT-problem-with-Esc-button/td-p/3638462
By accident, I discovered that the "gman.exe" process within CX-Programmer will cause the conflict by itself (it wasn't terminated correctly when I closed CX-Programmer).  Other processes may cause the problem also, but in this case as soon as I ended "gman.exe" from task manager the ESC key began functioning correctly.
I'm running CX-Programmer v9.31.  I've reported this to my Omron distributor and will post any helpfull info that comes from their side.  I'm curious if anyone else is experiencing this issue?  Any solutions or work-arounds?
Dell T7500, Xeon E5504 @2.0GHz, 12Gb RAM
Windows XP Professional x64
AutoCAD Electrical 2010 v2
New Member
jsaxin
Message 2 of 2 (278 Views)
Re: ESC key stops working
08-22-2013 12:53 AM in reply to: e-peery
I am having this same problem. There are a lot of really quirky things about CX-Programmer, but capturing the keyboard while in the background is just bush league.
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
