Well, I have created a dynamic block as one of my component symbols so I can stretch it as I need once it has been placed on the drawing. What I have noticed is that once I do stretch it, symbol will no longer respond to the "Component Update from Catalog" command. This is pretty critical. I need to have some flexibility to strech a symbol after I inser it (I do not want to have an assortment of different sizes) but I must be able to do updates from catalog when things change.
Thanks in advance,
Jeff
Ran into this when I was trying to make dynamic symbols. The problem is that when you do your stretch, that block gets assigned an "Anonymous Name" that prevents the system from recognizing it when doing a block update.
I think this is something that should be looked at by AutoDesk. On the one hand I can see reason's not to do the update, since the original block won't have the new location for the stretch handle. (Or other dynamicly altered values.) But like you, I can see it being very handy for some things.
AutoCAD Electrical don't support the Dynamic Block very well for now. Some features may fail for the Dynamic Blocks.
But I have put this request in our feature enhancement list.
Robin Shou
Quality Assurance
Autodesk AutoCAD Electrical
