AutoCAD Electrical General
Valued Contributor
JMARSHALL1249
Message 1 of 4 (267 Views)
Drawing template issues since 2013
267 Views, 3 Replies
07-17-2012 05:17 AM
Has anyone else had random parts of the drawing template being changed since the introduction of AE2013.
I have lines and company logo missing, which was generated as part of the original .dwt file.  The only was I can find to correct it is to copy and paste the circuit from the corrupt file into a blank sheet and rename it.
Does anyone hgave any idea what might be causing this.
Valued Contributor
JMARSHALL1249
Message 2 of 4 (264 Views)
Re: Drawing template issues since 2013
07-17-2012 05:28 AM in reply to: JMARSHALL1249
Looking at it further, it would appear the TITLE_BLOCK has changed somehow.  When I insert it into another drawing, the logo and grid lines display correctly.  I also deleted and purged the block from the drawing with the error, and inserted one from a different sheet and it was the correct one, with all grid lines and company logo.
What causes it to be changed in the first place though?
Icemanau
Message 3 of 4 (253 Views)
07-17-2012 04:03 PM in reply to: JMARSHALL1249
Did you check for layers that are turned off?
I've noticed that that when I import Layer settings, that layers not in the incoming settings get turned off even if they have objects on them. You may have something similar happening.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Valued Contributor
JMARSHALL1249
Message 4 of 4 (241 Views)
07-18-2012 04:14 AM in reply to: JMARSHALL1249
No, this was the first thing that I looked at.  All layers are turned on.
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
