AutoCAD Electrical Forum
Drawing List
5 REPLIES 5
870 Views, 5 Replies
Drawing List
I want to get all Drawings list of Active Project in Autocad electrical using vb.net?
Can we get?How?
Dim docs As DocumentCollection = Application.Preferences
For i As Integer = 0 To docs.Count - 1
 Dim doc As Document = docs(i)
Debug.Print(doc.Name)
Next
Iam using above code,but i get only one drawing name..
How should i get all drawings from Active Project? and I also want to Drawing Description for that Drawing using vb.net...
Please help how can i get?
Tags (1)
5 REPLIES 5
rhesusminus
Read it from the WDP-file, or from the scratch database for the active project.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Thank you sir,
Can we add extra Connections to PLC Symbol using .net?
rhesusminus
Yes, you can.
If you have a look at how the PLC symbols are built, you see that all the information needed for a connection point in ANY symbol is based oin attributes.
Via .NET you can add/remove all the attributes needed.
Trond Hasse Lie
Ctrl Alt El
If we want to create a line,we will need start point and end point only..
No other types of lines,
But if we want to add/modify PLC symbol,We should write code for every individual PLC,isn't?
Because, So many types of PLC symbols are there in AutocadE..the Connections are also Different for different PLC?
I want to add extra connections to PLC symbol using one form?but i cant able to create it..
I have created PLC as same as the AcadE's PLC symbol..Is anyway to Create it from a single form?
Can you understand my Query?
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. 😉
”Boost
