When you generate a Drawing List Report for the first time, you can change the displayed columns and then save them as a dwglst.set file.
I am using 2010 where I have changed and then saved the columns I want in subsequent reports. However, when I run the report again, it will not read the .set file and I end up having to change the columns again. The .set file is written to, but it is not read when the command is run again.
As a work around, you have to choose format and the pick the .set file each time the command is run where as before you didn't have to because it remembered.
There appears to be some kind of bug introduced since 2008 because this always remembered the columns between using the command.
Does anyone else have this problem? Has it been fixed in later versions?
Hi dbrblg,
Firstly thanks so much for your report this !! I validate this in the latest Autocad Electrical version and this issu still exists. We have tracked this in our issue tracking system for resolving.
Currently you can only use your workaround in your work, sorry for this and thanks for your support !
Kevin Li
SQA Engineer
@KevinLi-Autodesk wrote:Hi dbrblg,
Kevin Li
SQA Engineer
It appears to still be a problem. Bet tracking that one is easy. 'Cause it's just sittin there.
