AutoCAD Electrical General
Active Contributor
blackseabrew
Message 1 of 3 (414 Views)
Drawing Descriptions: Maximum of 3 Lines?
414 Views, 2 Replies
12-03-2011 07:00 PM
With certain customers we must show their titleblock information as well as ours.  Which for the drawing description means showing the three line desciption twice.  But their are only three drawing description lines to use in the drawing properties form.
Is there anyway to address this?  Can I give two different attributes the same name and have AE populate both of them with the same data?
Can I indicate tags DD4, DD5 & DD6 in the WDT file and modify the WDP file with additional drawing description lines?  See example below:
===PLC CONTROL SYSTEM
===ELECTRICAL SCHEMATIC
===SHEET 7
===SHEET 7
WC-3445-S07R1.dwg
I hope someone understands what I'm asking.  Thanks ahead of time.
Distinguished Contributor
JeffatICS
Message 2 of 3 (411 Views)
Re: Drawing Descriptions: Maximum of 3 Lines?
12-04-2011 06:18 AM in reply to: blackseabrew
As long as the blocks are defined the same they will show the same results. If both your title blocks can display the information block the same but be in different locaitons then that should work.
Icemanau
Message 3 of 3 (407 Views)
12-04-2011 02:15 PM in reply to: blackseabrew
Try pointing the attributes from their block to the same datapoints as your attributes use.
for example...
Your description line 1 = DD1
Your description line 2 = DD2
Your description line 3 = DD3
Their Description Line 1 = DD1
Their Description Line 2 = DD2
Their Description Line 3 = DD3
And so on for any other data they need duplicated...
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
