AutoCAD Electrical Forum
Drawing Config Default Values
4 REPLIES 4
krollenhagen
324 Views, 4 Replies
Does anyone know what file I need to change so that the I do not have to change the drawing config settings with every new drawing that I create?
4 REPLIES 4
in reply to: krollenhagen
The easiest way to do this for a project, so that
all new drawings in a project get the same configuration, is after configuring
the drawing to the way you like it, select the 'Compare Dwg and Prj
Settings' option.  Thi soption is found under the 'Electrical->Project'
pull-down menu or under the 'Config Drawing' flyout.
This command will allow you to compare the
differences between the current drawing and the project default settings and
change the project settings to match the current drawings settings.  Then
every new drawing created in this project will get these settings.
Steve Kemp
AutoCAD Electrical QA
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Does
create?
If you want to perminantly set your config
default you may either manually edit the
WD_M block (this is the config block
that gets inserted on your drawings)
you are using, or set your config
in a drawing and then in REPORTS, go to
SWAP WD_M, UPDATE WD_M. (the instructions
are straightforward) This will give you
a default config for all your drawings
Lynne
krollenhagen
Lint-
Thank you for you help. I did want a permanent solution.
Keith
A very common practice also is to create and use a
template drawing.  This is the process that is recommended and shown in the
training classes.
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
Lint-
Keith
”Boost
