I have a problem with an input block I've made. Attached is the AutoCAD block.
I click edit component and the 'edit PLC module' comes up.
When I put in any address as the first address (I used I:01/00) and hit the tab key on the keyboard it asks if I want octal, decimal, etc. I chose decimal and the first two addresses come up the same.
I:01/00, I:01/00, I:01/02, I:01/04.
I cannot figure out what is making this happen. The block seems good.
Using AutoCAD Electrical 2010. Any suggestions?
Mike
