AutoCAD Electrical General Discussion
Active Contributor
ddemerath
Message 1 of 3 (107 Views)
Disappearing PLC Information
107 Views, 2 Replies
01-07-2004 02:13 PM
I have presently defined an Allen Bradley 1762-IF2OF2 module for a Microlgix 1200. When I insert it into the drawing, all the default info shows up as expected. When I go into the module to edit the info so I can specify a location, I lose some of the default lines. I can put them in but they keep going blank. How can I get these values to stay put? The vales in question are:
Tag
Line1
Line2
Mfg
Cat
Location
Dick
Active Contributor
ddemerath
Message 2 of 3 (107 Views)
Re: Disappearing PLC Information
01-09-2004 09:31 AM in reply to: ddemerath
It turned out to be a header terminal used 3 times. I replaced the last 2 bad ones, and everything turned out ok.
*Nate Holt \(Autodesk\)
Message 3 of 3 (107 Views)
01-12-2004 07:02 PM in reply to: ddemerath
Dick, If you're willing to send me a sample dwg illustrating the problem below, I can take a look. Let me know. thanks, Nate. "ddemerath" wrote in message news:18229640.1073513688344.JavaMail.javamailuser@localhost... > I have presently defined an Allen Bradley 1762-IF2OF2 module for a Microlgix 1200. When I insert it into the drawing, all the default info shows up as expected. When I go into the module to edit the info so I can specify a location, I lose some of the default lines. I can put them in but they keep going blank. How can I get these values to stay put? The vales in question are: > Tag > Line1 > Line2 > Mfg > Cat > Location > > Dick
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
